help! Speedometer nd vtec don't work!!!
Old Oct 17, 2004 | 12:49 AM
Freshazzburu's Avatar
Default help! Speedometer nd vtec don't work!!!
recently my speedometer would kick in and out as i shift hard. the problem is that now the speedometer has shut off completely and hasn't come back on again. the engine check light is now on and the odometer doesn't count miles either. On top of that, my cruise control doesn't work and my vtec doesn't work ne more :'(. Please help me!
Old Oct 17, 2004 | 01:57 AM
b19coupe's Avatar
Default Re: help! Speedometer nd vtec don't work!!! (Freshazzburu)
Fix the wiring to your speed sensor or replace the speed sensor as needed. Inspect the connector closely for signs of corrosion-green stuff.
Old Oct 17, 2004 | 02:22 AM
Rocks
Guest
Posts: n/a
Dude its your vss. You vtec wont kick in because vtec needs to read at least 15 mph so it could kick in. i think . But I had this same exact problem and I bought the VSS and it took off. The speedometer shut off and my cel came on vtec wouldnt work . Same exact problem VSS.
Old Oct 17, 2004 | 08:53 AM
WickedKP's Avatar
something like that happened to me. my speedo would work fliker and work and die. Check the wiring ground at near the termostat housing.
Old Oct 17, 2004 | 12:02 PM
Default Re: help! Speedometer nd vtec don't work!!! (WickedKP)
Thanks guys...i will consider all of the replies and let u know what happens...time to get working on it!
Old Oct 17, 2004 | 02:09 PM
canuck-mx6's Avatar
VSS in on the tranny, just in case you are looking for it
Old Oct 17, 2004 | 02:45 PM
xmilanoredsix's Avatar
Default Re: help! Speedometer nd vtec don't work!!! (canuck-mx6)
cruise control.....who has cruise control
Old Oct 17, 2004 | 04:09 PM
99GEEzer's Avatar
i ran into the same problem. its your speedo fuse. the one in the bottom of your dash
Old Oct 17, 2004 | 10:12 PM
Default Re: (99GEEzer)
And we have a winner...the prize goes to 99GEEzer...the fuse was lose and is now back in stiff nd secure. Thanks a bunch!
anonymus913
Sep 15, 2011 06:59 PM
dointhemzs
Nov 13, 2008 10:31 AM
jaydm ferio
Dec 6, 2004 08:08 PM
Uniden
13
Sep 2, 2004 06:59 PM
aznplyboi15
Feb 24, 2004 06:28 PM
