break in questions na b20/vtec w/ uberdata
Old Oct 16, 2004 | 11:58 PM
96MidoriHatch's Avatar
Default break in questions na b20/vtec w/ uberdata
im getting ready to run it for the first time tommorow and i just have a few questions. I am running a p28 chipped for uberdata with a gsr base map and I was told that the gsr base map may make the motor run too rich for the break in?? i thought that if anything it would be lean, anyways just wondering if anyone else has done this and what was the outcome or suggestions on what i should do. btw it has eagle rods and 11.5:1 je pistons.
Old Oct 17, 2004 | 06:31 AM
drdisco69's Avatar
Default Re: break in questions na b20/vtec w/ uberdata (96MidoriHatch)
Wideband O2 is your friend.
Old Oct 17, 2004 | 06:47 AM
non-VTEC's Avatar
the p28 with a gsr base map should run borderline lean with the stock injectors and a 2L bottom end.
it might be ok for break-in but maybe try to add 2-3% more fuel everywhere. just to be safe. try to get a widband o2 to measure the A/F properly.
Old Oct 17, 2004 | 08:57 AM
Default Re: break in questions na b20/vtec w/ uberdata (non-VTEC)
thanks for the advice guys, i bought a normal autometer air/fuel just to make sure it doesn't go too lean or rich until i make it to the dyno, is that sufficient or are those things a joke?
Old Oct 17, 2004 | 09:22 AM
DaZman69's Avatar
no they very accurate, just as accurate as a wideband, they just don't tell you how rich or how lean, which is why widebands are nice. If the autometer says your stoich, u can bet ur *** u actually are.
Old Oct 17, 2004 | 10:46 AM
Default Re: break in questions na b20/vtec w/ uberdata (DaZman69)
thankx thats what i was hoping
Yo dude 13
12
Aug 20, 2012 04:40 AM
dansXR2
Mar 10, 2010 08:36 PM
Mr.Kalinchuk
13
Mar 4, 2009 05:55 PM
w0ng_sta
Jun 25, 2007 05:20 AM
Azn Kenny
Aug 20, 2006 12:28 PM
