summer time lean out?
Old Jun 10, 2007 | 09:46 AM
w0ng_sta's Avatar
Default summer time lean out?
Sup, havent been here for a while,
Have a mostly stock b16 on 8.5 psi right now. Got tuned in winter and the motor usually idled at around 14-15 a/f.. but now its summer and its been idling at about 17-18. Given that the air outisde is warmer wouldnt the tune theoretically rich out? cuz it seems that the overall map has leaned out just slightly. I duno if im retarded or something but i figured the cooler the ambient air the leaner the motor would run assuming how I drive is kept consistant =x?
Old Jun 14, 2007 | 08:46 AM
w0ng_sta's Avatar
Default Re: summer time lean out? (w0ng_sta)
bump
Old Jun 14, 2007 | 11:57 AM
Buzzbomb's Avatar
What kind of EM do you have?
Old Jun 22, 2007 | 06:35 PM
w0ng_sta's Avatar
Default Re: summer time lean out? (Buzzbomb)
hondata s200w/b
running off map no connected o2
actualyl thats a good poitn.. if i plug my wideband in now will it start to adjust the tune automatically?
Old Jun 22, 2007 | 07:02 PM
bigbadboy's Avatar
you should have your o2 hooked up so you can run in closed loop
Old Jun 22, 2007 | 07:49 PM
blackeg's Avatar
Default Re: (bigbadboy)
expletive closed loop.
normally your car should run richer during the summer (air is warmer = expands = less dense = less o2 molecules = too many fuel molecules per unit volume = running rich)
you might have something else going on.
Old Jun 22, 2007 | 08:34 PM
iBrandon's Avatar
Default Re: (blackeg)
Dont touch ur fuel tables! Look into your correction tables...adjust from there.
Old Jun 25, 2007 | 05:20 AM
Buzzbomb's Avatar
Default Re: (iBrandon)
Not familiar with Hondata, but I'm sure it has correction tables for ECT and IAT. Probably what is happening is there is a multiplier that is too low in one or both tables making you run leaner
Adjustments in those tables should correct the problem.
I would also recommend running in closed loop. It adjusts for alot of changing weather variables, especially in a changing climate region.
raidacaipo
Jun 7, 2008 04:24 PM
Btothe3rdDegree
Apr 4, 2004 05:43 PM
VtecDA9
Oct 6, 2003 09:07 PM
90teg
Jul 5, 2003 10:32 PM
Hybrid
Jun 18, 2003 05:02 PM
