How to find VE(volumetric Efficiency)?
Old Dec 17, 2001 | 02:16 PM
HXMan's Avatar
Default How to find VE(volumetric Efficiency)?
How do you find that for an engine?
All I really want to know what is the VE for a b16a2??
Old Dec 17, 2001 | 02:21 PM
Spade's Avatar
Default Re: How to find VE(volumetric Efficiency)? (HXMan)
Congrats man on the Drag III INSTALL IT NOW!!!!
Old Dec 17, 2001 | 02:37 PM
HXMan's Avatar
Default Re: How to find VE(volumetric Efficiency)? (Spade)
he he he....problem are:
1. I need to pass smog in april or may, so install will have to be after that.
2. I need about $1500 worth of more stuff for this to work the way I want it too!
Old Dec 17, 2001 | 04:02 PM
HXMan's Avatar
From http://www.prestage.com/carmath/formulas.asp
volumetric efficiency = acutal cfm / theoretical cfm x 100
theoretical cfm = rpm x displacement / 3456
Now...if only I can find the actual CFM of a b16a2, and a 4g63(for my friend).
Old Dec 17, 2001 | 04:29 PM
dohc_Cx's Avatar
New User
what else are you going to be getting?
Old Dec 17, 2001 | 07:27 PM
HXMan's Avatar
Default Re: How to find VE(volumetric Efficiency)? (rACEr_b_O_y_)
Well, for one, I only have hondata stage 3....I need to upgrade to boost.
Thats $345
Plus I need:
Clutch
Eclipse 450 injectors
Resistor pack
1:1 FPR
High Flow fuel Rail
Fuel Pressure Guage
Greddy EGT Guage
Walbro 255lph intank pump
High flow AEM fuel filter
+ little odds and ends
Oh, and then there is the 190/hr they charge at Payne Tech in michigan to dyno tune hondata!
fastasscrx
Sep 23, 2005 05:19 PM
opto_isolator
Dec 14, 2003 08:41 PM
redline201
Feb 6, 2003 08:02 PM
jamal-188
Sep 17, 2002 09:25 AM
civicdragon
Feb 11, 2002 09:14 PM
