MAP sensor wiring help!!!
OK i just bought a engine harness but it doesnt have a map sensor harness on it. so now i have to wire up a map sensor directly o the ECU. now there are 3 wires on the MAP sensor. I need to know which one to run to the ECU which one do i hook up to a 12 volt and which one do i ground? the wires are
Green w/ black
Red w/ black
Yellow/ Green
Green w/ black
Red w/ black
Yellow/ Green
Hmm I just looked at my 1994 Integra service manual and the wires are as follows:
YEL/WHT [(+) for B18C1] or YEL/RED [(+) for B18B1]
GRN/WHT (-)
WHT/YEL (+)
I'm not sure which one's for ground. I hope his helps though.
For some reason your colors are different, what wiring harness are you using?
GRN/WHT (-)
WHT/YEL (+)
try this from hondata.
http://www.hondata.com/3barinstall.html
and i got this from my eg manual.
yellow/green to d19
white to d17
green/white to d21
please double check before. but HTH.
try page 11-54 in an eg service manual to help you.
yellow/green to d19
white to d17
green/white to d21
Slacker93eg
Sep 12, 2012 09:48 AM
hondaboy4life
Aug 14, 2006 07:20 PM
