Will i need vavle/springs and retainers?
Heres my setup:
Head:
P&P Ls head w/ valve job
Crowers 402's cams w/ skunk2 gears
skunk2 intake manifold
74mm TB
Nology Wires
550's (planning to upgraded) w/ Walboro 255lhp fuel pump etc....
Block:
Golden Eagle b18b1 Sleeve/bore/hone 81mm
Eagles Rods H-Beam w/ ARP Rod bolts
Wiseco Pistions
Micro crank all those little tihngs....
Custom Kit:
Garrett T04E 60a/r w/ Stage 3 turbine
SP Log Manifold
SP 2.5-3" dp all the way back
HKS BOV
Drag IC (planning to upgrade)
Tial Wastegate 38mm
Those are some of the major stuff, do i need to upgrade the valves/springs and retainers?? Im not planning to over rev it, but i want at least 350-400hp, i know that you dont need them unless you planning to rev over redline and some say you'll need it no matter what...so im confuse now....Big Turbos Guys i need some help. thanks
Modified by sPaRk'iT at 2:49 AM 10/17/2004
Modified by sPaRk'iT at 9:54 PM 10/18/2004
Head:
74mm TB
Nology Wires
Block:
Wiseco Pistions
Custom Kit:
SP Log Manifold
HKS BOV
Tial Wastegate 38mm
Upgraded valvetrain is always good for high hp setups whether its turbo or all motor.
Having a strong valvetrain will prevent valve float at high RPM. and especially when boosting, you want a bit more RPM over stock to take advantage of more boost.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sPaRk’iT »</TD></TR><TR><TD CLASS="quote">Sounds like im upgrading the springs/retainers, will stock valves hold fine?</TD></TR></TABLE>
how high do you plan on reving?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2eg »</TD></TR><TR><TD CLASS="quote">id upgrade just for peace off mind knowing the motor will continue to run strong, just my opinon tho</TD></TR></TABLE>
Exactly. You put in so much money into your setup. a good valvetrain is a preventative measure since stock valvetrains have already gone through their wear and tear through the years.
19sec beast
Feb 25, 2006 01:51 PM
