Break clips (how do they mount on the pad/caliper)
Old Oct 16, 2004 | 02:43 PM
menkio's Avatar
Default Break clips (how do they mount on the pad/caliper)
I just re-did my brakes, cleaned/glass beaded and got new rotors, pads and what not. I'm having problems putting the pads on so they stay off the rotor. I think the clips got bent. Anyone have a diagram or what not for how they latch on.
(sorry about title, i just watched team america)
Old Oct 16, 2004 | 02:47 PM
ABK's Avatar
ABK
Default Re: Break clips (yanta)
did you glassbeed the calipers? if you did chances are you f them up.
if you calipers are not seized and your hardware kit is good then it's fine, your pads can touch the rotors (they are not really dragging).
Old Oct 16, 2004 | 02:54 PM
menkio's Avatar
Default Re: Break clips (ABK)
ohh, ok, i always thought they rest a bit off the caliper... the brake pistons works fine thow.
Old Oct 18, 2004 | 10:25 AM
JokerTypeR's Avatar
I second the opinion. Since the day I've gotten my civic and even when I drove my dodge ram and worked on others, it naturally sits slightly on the rotor/disc. It can't naturally push all of the fluid out of the piston. Just make sure your disc/rotor still free spins...or...as much as it can free-spin with all the weight and other components and such.
88 EF Hatch
Suspension & Brakes
Apr 21, 2009 12:00 PM
M4
May 30, 2005 09:01 PM
seer_claw
Feb 24, 2004 08:13 PM
wizzards581
16
Sep 17, 2003 06:16 PM
st0ne
11
Jun 4, 2003 03:41 PM
