Power Windows conversion
Old Oct 16, 2004 | 02:07 PM
YoungChrisEG's Avatar
Default Power Windows conversion
HEY WHATS UP
I HAVE A QUESTION??? DOES ANY ONE KNOW HOW TO CONVERT A 1992 CIVIC VX TO POWER WINDOWS? I HAVE THE MOTORS AND THE WIRING BUT I DONT KNOW WAT ELSE YOU NEED? PLEASE GIVE ME SOME ADVISE ON HOW TO DO THIS!
Old Oct 16, 2004 | 02:08 PM
CivicEX96's Avatar
Default Re: Power Windows conversion (YoungChrisEG)
if you turned off your caps lock key you might get someone to help you out and not ignore you...
Old Oct 16, 2004 | 02:40 PM
mc's Avatar
mc
you will also need the power window relay that plugs into your fuse box and fuses in the correct spots for the power windows and the door panel switches. There is a harness that plugs into the back of the fuse box that you should have also. I found it easier to just temporarily do the wiring first to make sure everything works then install the motor and do all the wiring one window at a time. Here is a link to a schematic of the wiring. http://www.honda.co.uk/owner/c...3.pdf
I am not sure if the colors are correct though because that is out of a UK service manual. Also if you search around here I know there is a link to a website that shows how to.
bpeters2
Dec 14, 2015 08:31 AM
heffer0123
May 16, 2011 06:19 AM
-[95cxhatch]-
May 26, 2008 08:50 AM
@irborne
Mar 5, 2003 09:45 AM
BigDaddyRich
Aug 22, 2002 11:09 AM
