Power Windows conversion
HEY WHATS UP
I HAVE A QUESTION??? DOES ANY ONE KNOW HOW TO CONVERT A 1992 CIVIC VX TO POWER WINDOWS? I HAVE THE MOTORS AND THE WIRING BUT I DONT KNOW WAT ELSE YOU NEED? PLEASE GIVE ME SOME ADVISE ON HOW TO DO THIS!
Re: Power Windows conversion (YoungChrisEG)
you will also need the power window relay that plugs into your fuse box and fuses in the correct spots for the power windows and the door panel switches. There is a harness that plugs into the back of the fuse box that you should have also. I found it easier to just temporarily do the wiring first to make sure everything works then install the motor and do all the wiring one window at a time. Here is a link to a schematic of the wiring. http://www.honda.co.uk/owner/c...3.pdf
I am not sure if the colors are correct though because that is out of a UK service manual. Also if you search around here I know there is a link to a website that shows how to.
-[95cxhatch]-
05-26-2008 08:50 AM
BigDaddyRich
08-22-2002 11:09 AM
