coolant problem...
when will you fill up your coolant? i dunno what happen, but i have to fill up the coolant every week, it runs from the max to min for only 1 week....it used to last for few weeks or more.....i noticed that one of the pipe leaking when i look under my car, but just few drops of coolant whenever i start the car in cold weather, once it warms up, it doesn't leak anymore, but the next morning, it happens again..anyone got the same problem? well, i don't bother to fix that since it only leaks whenever i start the car tho..
try replacing the hose... ur car should never leak coolant... if it does.. then your radiator is either cracked... or the rubber hose has gone bad.. either way get it checked out.....filling up coolant even every week is NOT normal
get it fixed, if your reservoir is going down and you see the coolant leaks, then you should fix it, you definitely should not have to fill your coolant every week........
tFUnK
Jan 2, 2003 12:56 AM
