static in speakers when radio is on
will i put a system in my car and now when the radio is playing is sounds like static or cracking in the speakers and i can't find what it is caused from i have 2 12 alum 12's with a ultra linea 3000 watt amp with a spar bat. if any one can help that would be great thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpmac10 »</TD></TR><TR><TD CLASS="quote">will i put a system in my car and now when the radio is playing is sounds like static or cracking in the speakers and i can't find what it is caused from i have 2 12 alum 12's with a ultra linea 3000 watt amp with a spar bat. if any one can help that would be great thanks </TD></TR></TABLE> If it only happens when playing the radio anr not the cd,[ or hehe tape] the problem is in the HU, [radio part ] or the antenna or the connection between the two, if you are lucky, it will be the connection, [make sure it is a good one] not so lucky, it will be the ant., [ have it checked and replaced if no good] if you are having a bad day, it will be the HU,[ you will have to remove it and take it to a repair shop.
94
94
hey thanks for the relpy's but i found out what it was, it was bad spark plug wires they where letting the spark out and cause static in my car. found that out the hard way when i touched one when the car was on and got a pretty good shock. know my radio is crystal clear sounding .
patrick4588
Audio / Security / Video
11
Feb 18, 2008 09:33 PM
acuraLSSE95
Nov 4, 2002 06:06 PM
