ignition
i've got a sport compact msd ignition and a friend put on a blaster 2 coil... Now all of a sudden the cars battery wont hold any charge and sucks mad.... before it had a blaster SS.... can the coil be too big be shorting out something or doing anything to harm something? (im not good with stuff like this)
Find out whether it's a coincidence... Disconnect the battery cables overnight. If it STILL loses the charge you know it's the battery's fault.
If it holds a charge disconnected, then you have to find something that doesn't turn off. Since you just installed the coil (& anything else new??) that's probably where you should look for something hooked up wrong.
boozer
Sep 16, 2015 04:24 AM
