What head gaskets you guys use??? (D16)
Old Oct 15, 2004 | 07:24 PM
JDMTurboCivic11's Avatar
Default What head gaskets you guys use??? (D16)
I was just wondering what head gaskt you guys use for a Boosted SOHC. Im changing mine but not sure what kind to get.
Old Oct 15, 2004 | 08:05 PM
sleeping GIANT's Avatar
Default Re: What head gaskets you guys use??? (JDMTurboCivic11)
d16y8 !
Old Oct 15, 2004 | 08:21 PM
mpintegra96's Avatar
its not a d16 but in my b18 ive got a 2mm cometic headgasket, in one of my buddys civics with a d16 he has a 2mm cometic headgasket too, from what ive heard there pretty good
Old Oct 15, 2004 | 08:35 PM
Bailhatch's Avatar
Default Re: What head gaskets you guys use??? (mpintegra96)
what motor was that again? stock mls is great for my z6
Old Oct 15, 2004 | 09:19 PM
beerbongskickass's Avatar
Default Re: What head gaskets you guys use??? (Bailhatch)
Honda OEM head gasket, few coats of copper spray, and arp head studs... just replaced mine a few weeks ago.
Old Oct 16, 2004 | 09:34 PM
PrettyLude's Avatar
you'd be surprised at what the factory oem headgasket can do.
Old Oct 16, 2004 | 09:53 PM
Boltz's Avatar
Default Re: (PrettyLude)
Oem w/RTV
Old Oct 16, 2004 | 10:18 PM
jDMJeRk's Avatar
ive always been told that OEM is the best hg for a honda. you can never turn down OEM
Old Oct 17, 2004 | 08:13 AM
djwest24's Avatar
Default Re: What head gaskets you guys use??? (jDMJeRk)
i use the OEM ones. but i've heard a lotta good things about cometic.
Old Oct 17, 2004 | 08:17 AM
SOHC_MShue's Avatar
i'll probably never use any gasket, but oem for my d16.
Old Oct 17, 2004 | 08:49 AM
99lspwr's Avatar
Default Re: What head gaskets you guys use??? (beerbongskickass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">Honda OEM head gasket, few coats of copper spray, and arp head studs... just replaced mine a few weeks ago.</TD></TR></TABLE>
Just did the same a week or two ago myself (minus the copper spray) and it seems to be working out very well... No more lifting the head, thank god!!
Old Oct 17, 2004 | 09:23 AM
RyanEJ8's Avatar
OEM D16Y8
Old Oct 17, 2004 | 09:38 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
I did the same, but 2 months ago.
2k miles later, car runs mint
Old Oct 21, 2004 | 10:23 AM
94greddycivic's Avatar
does anyone get the head and the block resurfaced when doing the HG.....ive heard its good to do , but is it necessary , if not when would it be necessary to do it
Old Oct 21, 2004 | 10:28 AM
fjt's Avatar
fjt
Default Re: What head gaskets you guys use??? (94greddycivic)
Y7 motor..Y7 OEM HG and ARP studs
Old Oct 21, 2004 | 03:20 PM
pip9's Avatar
Default Re: What head gaskets you guys use??? (fjt)
i used a y8 one with my z6block/y8head. coppersprayed, arp head studs, and torqued to 70ft/lbs. The y8 one will give u alittle higher compression ratio and its half the price of the z6 one.
Old Oct 22, 2004 | 06:46 AM
dester223's Avatar
If you have a machinist straight edge, you can measure if there is any warpage within the head. If it's warped. (I think it's like .005 damn, or is it .0005 Too early to think) or more, then a resurface is a good idea.
Old Oct 22, 2004 | 06:51 AM
yellowturbo's Avatar
OEM and you will be fine !
Freshdot
Sep 20, 2010 10:41 AM
victoriasamantha
Oct 15, 2008 11:31 AM
blackccoupe
Aug 27, 2008 08:52 PM
jarven093
Mar 3, 2007 10:39 PM
HONDA RR
Apr 6, 2005 06:22 AM
