Need a new timing belt but not sure what to use b20vtec (b16a1 head, b20b block) ?
Old Oct 15, 2004 | 04:53 PM
saer's Avatar
Default Need a new timing belt but not sure what to use b20vtec (b16a1 head, b20b block) ?
Sup everyone I just noticed out of the blue that my timing belt on my b20vtec setup has a slight tear in it, im not exactly sure where it came from. I plan on changing my timing belt asap but im not sure which to go with ?
The setup is a b16a1 1st gen head with a jdm b20b bottom end. Im also not sure if the block is using a b16 or a b18c oil pump. Do I need a b16 or b18c timing belt ? or does this question reflect on which oil pump im running ?
If your wondering why Im not sure which to go with well its because I bought the motor already assembled and wasn't sure what belt was already on the motor.
Old Oct 15, 2004 | 06:15 PM
RedZone's Avatar
Default Re: Need a new timing belt but not sure what to use b20vtec (b16a1 head, b20b block) ? (deka`)
It depends on the water pump not the oil pump....Best thing to do it to just change the timing belt and water pump to a b20 or B18C......
Old Oct 15, 2004 | 06:20 PM
eg_type_r93's Avatar
Default Re: Need a new timing belt but not sure what to use b20vtec (RedZone)
what does your water pump say 19 or 22? on the gear
Old Oct 15, 2004 | 08:13 PM
saer's Avatar
Default Re: Need a new timing belt but not sure what to use b20vtec (eg_type_r93)
im not sure whats the 19 or 22 indicate ?
Old Oct 15, 2004 | 08:30 PM
The Destroyer's Avatar
Default Re: Need a new timing belt but not sure what to use b20vtec (deka`)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deka` &raquo;</TD></TR><TR><TD CLASS="quote">im not sure whats the 19 or 22 indicate ? </TD></TR></TABLE>
It indicates the amount of teeth on the waterpump I beleive.
lilskud13
14
Mar 26, 2009 01:28 PM
ekturbohatch22
May 11, 2007 07:25 PM
gtturborex
Sep 23, 2005 04:59 AM
Hondasaurs
Jul 30, 2003 09:12 PM
Integra-T
May 11, 2002 02:21 AM
