wHat the hell kinda pistons is this?
looks like some crazy high compression custom made piston.
import builders has some pistons that look kinda like that. compression ratio would be over 15:1 or something like that.
yeah that is a Import Builders piston. the guy whos motor that is, is working with Jeff (owner of import builders) to do that build I think the compression is around 15.5:1 or something crazy. motor also had Golden Eagle Godzilla sleeves..
And just think, my stock sleeve GSR motor with off the shelf pistons and rods will be just as fast if not faster than the car powered by that high dollar motor running on straight race gas. Call me crazy, but I never got the attraction of building a naturally aspirated small displacement 4-cylinder.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT »</TD></TR><TR><TD CLASS="quote">So your car is gonna be running 10s on stock sleeves?</TD></TR></TABLE>
And Whats so outrageous about that?
Who is Mr Robot?
thats the aem car for bonneville, its a short stroke b16 thats supposed to run like a 13:5:1 cr. I beleive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT »</TD></TR><TR><TD CLASS="quote">Nothing outrageous about it, it just happens in 1 of a 10000 hondas being able to run 10s on stock sleeves.</TD></TR></TABLE>
not true at all my friend, i can name more then two hands full right now
11.66 @ 130 on bald 24.5/8.5/15 slicks, no LSD, pump gas, stock sleeves, 16 psi. I need to get my traction issues settled, then I'm going to crank the boost up at the track. I've already had it as high as 24 on the street, which should be more than enough trap speed to crack a 10. And guess what? My car has power steering, comfy leather seats, a stereo, and I can pull into shell and fill it up on premium. Like I said, I never saw the joy in building a small displacement motor that runs on race gas, tossing it in a gutted race car and running 10's in something that you can't drive on the street comfortably.
more info
https://honda-tech.com/zerothread?id=991796
i know of 2 motors that run those pistons that make over 250whp
one is a 86mm and i forgot about other, i think 2.1?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost »</TD></TR><TR><TD CLASS="quote">thats the aem car for bonneville, its a short stroke b16 thats supposed to run like a 13:5:1 cr. I beleive</TD></TR></TABLE>
No, thats not the AEM/Golden Eagle Bonneville engine. It looks similar but not the same.
allmotorpackage
Nov 9, 2008 11:38 PM
scspeed
Sep 18, 2008 02:26 PM
scspeed
Sep 16, 2008 06:26 PM
GusRock77
Honda S2000
16
Mar 1, 2005 12:24 PM
