ABS Fuse
Old Oct 15, 2004 | 07:05 AM
rastropovitch
Guest
Posts: n/a
Default ABS Fuse
anyone know which fuse to pull in the generation 2 integra to disable the abs system? It keeps cycling and I want to disable it for now. anyone know why it would keep cycling? it is not constantly running, but ever minute or two it will run for about 3-5 seconds... Low Fluid? Fluid does not look low inthe res
Schu
Old Oct 15, 2004 | 07:21 AM
drdisco69's Avatar
Default Re: ABS Fuse (MSchu)
There could be air trapped in the lines, causing the motor to keep trying to build pressure. There is a separate fuse box for the ABS. You can pull the pump motor relay instead. Look for the box between the battery and the abs modulator assembly.
Old Oct 15, 2004 | 07:24 AM
rastropovitch
Guest
Posts: n/a
Default Re: ABS Fuse (drdisco69)
Pump motor relay??? Nice... let me look. I have all the lines for a abs delete retrofit... I am just lazy
Old Oct 15, 2004 | 07:26 AM
drdisco69's Avatar
ABS delete retrofit? Where did you pick those up at? My friend has a 2nd gen integra and he's interested in getting rid of ABS too. I don't know why, I wish I could put in on my CRX. I <3 ABS.
Old Oct 15, 2004 | 07:34 AM
rastropovitch
Guest
Posts: n/a
Much better brake feel... You friend will need to get the entire brake line and porportioning valve from an 90-93 RS or nonabs chassis. you can find them at many car dismantelers. you need all hard lines... about 5-6 and the valve, thats it. just becareful when removing the system fom the abs car... it is underpressure
Schu
PS.. makes the enginebay much cleaner looking and takea bit of weight off the car
Old Oct 15, 2004 | 07:37 AM
drdisco69's Avatar
We were thinking of running the lines to a fabricated block, basically a brake line to brake line adapter, and then bending up new lines to the master cylinder. That would at least eliminate the hassle of replacing ALL the lines. Ugh. Are the proportioning valves different, or just have the lines in a different place?
Queen - Under Pressure
Old Oct 15, 2004 | 07:47 AM
rastropovitch
Guest
Posts: n/a
You can absolutely use an aftermarket porportioning valve... not a problem. you can use steel braided lines to route them anywhere you want to. you just need the correct dash (-)size, and hondaas already shaped hard lines, so why not use them. you don;t need the lines to the wheels, just the lines under the hood
Old Oct 15, 2004 | 07:51 AM
drdisco69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MSchu &raquo;</TD></TR><TR><TD CLASS="quote">you don;t need the lines to the wheels, just the lines under the hood</TD></TR></TABLE>
Whew, I had terrible visions in my head. Thats just what I needed to know. Thanks you.
brian1037
Honda Civic (2001 - 2005)
14
Aug 23, 2011 07:49 PM
vxnine
Jul 24, 2006 05:33 PM
seifer
Mar 23, 2005 07:59 PM
fw190bvi
Jan 7, 2004 11:20 AM
