Honda S2000 Honda S2000
where is ecu located in s2k?
Old Oct 14, 2004 | 08:30 PM
fkncivic's Avatar
Default where is ecu located in s2k?
friend needs to know cause he is throwing a cel....
Old Oct 14, 2004 | 08:33 PM
LSHatch's Avatar
Default Re: where is ecu located in s2k? (fkncivic)
It's located behind the drivers side kick panel up near the clutch pedal.
Old Oct 14, 2004 | 08:35 PM
fkncivic's Avatar
Default Re: where is ecu located in s2k? (LSHatch)
thanks man nice quick answers rule lol
Old Oct 14, 2004 | 08:45 PM
LSHatch's Avatar
Not a problem. Good luck getting the problem fixed. It's problem something small anyway.
Old Oct 15, 2004 | 03:57 PM
Mr. Bagel's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fkncivic &raquo;</TD></TR><TR><TD CLASS="quote">friend needs to know cause he is throwing a cel....</TD></TR></TABLE>
update?
also, just because it is throwing up a CEL doesn't mean you need to know where it is. there are two ways to see if it a bogus CEL or not: disconnect battery (not recommended since you need to reset the radio etc.) or a fuse. Search on s2ki to locate the correct fuse. I cannot remember at the moment but I know how to feel for it under the dash.
Old Oct 17, 2004 | 06:04 PM
supracar's Avatar
Default Re: where is ecu located in s2k? (Mr. Bagel)
bump
jordan71
Apr 8, 2008 05:42 PM
srb7f
13
Oct 20, 2005 10:41 PM
es_squared
Apr 3, 2004 05:05 AM
JunIntegra
Sep 15, 2003 03:51 PM
CPR
Aug 21, 2003 09:04 AM
