Billows of smoke when starting car
Old Oct 14, 2004 | 07:02 PM
Hondadrvr215's Avatar
Default Billows of smoke when starting car
I'm running turbo w/ straight pipe (no cat)
When i start the car, there is a HUGE billow of White smoke that subsides after about 1 min or until the car is warmed up.
What is it? steam...non combusted fuel? Any other turbo folks have this issue?
Old Oct 14, 2004 | 07:08 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Billows of smoke when starting car (Hondadrvr215)
what color is the smoke?
Old Oct 14, 2004 | 07:15 PM
Default Re: Billows of smoke when starting car (Hella_JDM)
White Smoke
Old Oct 14, 2004 | 07:22 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
My car does the same thing. I was told that i need to replace the valve stem seals...but who knows. Good luck though
Old Oct 14, 2004 | 07:25 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Billows of smoke when starting car (sCeRaXn)
thats oil or coolant....sounds like your turbo is shot.
Old Oct 14, 2004 | 07:26 PM
PrettyLude's Avatar
either that or rings or worn
Ri5e's Avatar
Is your turbo water cooled?
Old Oct 14, 2004 | 07:38 PM
yup..water cooled T4 Ball bearing turbo.
any permanant damage?...I can't afford to replace or rebuild my turbo
I'll just make sure coolant levels are adequate at at all times
Old Oct 14, 2004 | 07:51 PM
Bailhatch's Avatar
usually that is valve guide seals.
Old Oct 15, 2004 | 05:59 AM
If the seals are an issue, I can just re-add coolant, will there be any further denigration of the turbo? I can't afford a rebuild right now if a rebuild is in order
Old Oct 15, 2004 | 08:27 AM
djwest24's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondadrvr215 &raquo;</TD></TR><TR><TD CLASS="quote">If the seals are an issue, I can just re-add coolant, will there be any further denigration of the turbo? I can't afford a rebuild right now if a rebuild is in order </TD></TR></TABLE>
i think Bailhatch meant the head
Old Oct 15, 2004 | 09:31 AM
DruWO's Avatar
if your car is running rich, it usually blows a cloud of smoke when you first start your car...
Old Oct 15, 2004 | 10:02 AM
Stewie's Avatar
Default Re: (DruWO)
the only way to tell is to inhale the smoke
Seriously, it could be just condensation. If it's oil, it will have a real bad smell to it almost unbearable to breath. If it's just condensation, it'll have a light smell of gas. If it's coolant, it'll smell sweet and make you hungry.
Old Oct 15, 2004 | 10:05 AM
CRX T-Si's Avatar
Default Re: (DruWO)
My car when I start it in the mornings lets off a small cloud of white smoke.
It only does it when the car being sitting over night. Since I let the car warm up about 5 mins before I actually drive it, when I do put it in gear and give it a little gas you see the smoke. While it's at idle you only see it if your actually looking at the tail pipe.
Check your valve seals. If you take your spark plugs off, with a flash light look down. If it's shiny/wet then you know whats up. If not then look at your turbo turbine housing or DP for traces of burnt oil residue.
Mine is the valve seals, just a little.
jose5673
Sep 22, 2014 04:41 PM
ChrisCrankz96
May 3, 2013 06:34 AM
sohc_kuhol
Mar 28, 2008 04:53 PM
91glassycrx
Apr 21, 2004 12:49 PM
turbo__D
Feb 1, 2004 04:51 PM
