LS/VTEC COMPRESSION TEST AFTER REBUILD
Old Oct 14, 2004 | 07:00 PM
punkracer's Avatar
Default LS/VTEC COMPRESSION TEST AFTER REBUILD
WELL AFTER MY VERY SUCESSFULL engine rebuild i am in the middle of breaking it in. i am at 614miles and decided to do a compreesion test.. well i have a 96 b18b1 block and a 99 si vtec head acl bearing and ARp studs. well the test resulted in 210 all across the board.. my question is is this normal?? and does this mean my engine is broken in???
i am still going to run it till 1000 miles and then change out to synthetic oil (molbil 1, baBY)
Old Oct 14, 2004 | 07:03 PM
Muckman's Avatar
Moderator in Chief
Default Re: LS/VTEC COMPRESSION TEST AFTER REBUILD (punkracer)
of course its normal.
your motor is well broken in. enjoy
Old Oct 14, 2004 | 07:06 PM
drdisco69's Avatar
What break-in procedure did you use?
Old Oct 14, 2004 | 09:33 PM
punkracer's Avatar
Default Re: LS/VTEC COMPRESSION TEST AFTER REBUILD (drdisco69)
the take it easy method
Old Oct 14, 2004 | 10:11 PM
ExospeedAMcrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by punkracer &raquo;</TD></TR><TR><TD CLASS="quote">the take it easy method</TD></TR></TABLE>
haha.. im gonna have to use that one.
Old Oct 15, 2004 | 04:58 AM
drdisco69's Avatar
Thats interesting. I would like to see compression and leakdown tests on a motor that was broken in with the "drive it like you're going to drive it" method. Unless this exists because I haven't searched yet...
Old Oct 15, 2004 | 10:36 AM
Muckman's Avatar
Moderator in Chief
I broke in my 9:1 motor very hard for the first 250 miles. I have 190psi across all cylinders +-5. Im very happy with how it turned out.
Old Oct 15, 2004 | 11:07 AM
drdisco69's Avatar
Default Re: LS/VTEC COMPRESSION TEST AFTER REBUILD (Muckman)
190 is very good on a 9:1. Thanks for the info. Anyone else?
Old Oct 23, 2004 | 07:36 PM
Noch's Avatar
BUMP cause i'm curious to know too
carlos8
Aug 2, 2016 02:57 PM
berettagtz117
Mar 6, 2007 04:09 PM
Fat Chick Magnet
Sep 28, 2006 06:24 PM
mountaindewguy
Jan 16, 2006 07:46 PM
gsr~hatch
Apr 17, 2003 03:19 PM
