lsvtec oil pressure
Old Oct 14, 2004 | 06:54 PM
prettysweetcivic's Avatar
Default lsvtec oil pressure
What is the oil pressure in a lsvtec supoused to be around????
and....
When warm at 800rpm?
Old Oct 16, 2004 | 03:02 PM
Default Re: lsvtec oil pressure (Copenhagen Honda)
bump
Old Oct 16, 2004 | 03:12 PM
UnKnownUser's Avatar
bump i like to know when at all rpms...
Old Oct 18, 2004 | 04:20 AM
Default Re: lsvtec oil pressure (LSVTEC DC4)
BUMP
Old Oct 18, 2004 | 05:30 AM
IN VTEC's Avatar
Typical warm idle pressure is 10-15psi.
Old Oct 18, 2004 | 05:50 AM
Default Re: lsvtec oil pressure (IN VTEC)
Mine..
Warm idle 21-22psi, warm idle with accessories on 18-19psi, psi at 3000rpm 80psi.. just wanted to check.
Old Oct 18, 2004 | 06:10 AM
per4mance's Avatar
my ls/vtec when i first crank it up i goes to 60 psi, then stays around 20 or so when gets warm
Old Oct 18, 2004 | 06:31 PM
Default Re: lsvtec oil pressure (per4mance)
bump
Old Oct 18, 2004 | 08:50 PM
93lsd's Avatar
mine is 10-20 at warm idle and above 3,000 is at 80 and at wot is 85-90
Old Oct 19, 2004 | 03:23 PM
Default Re: (93lsd)
bump - more lsvtecers post please
Old Oct 19, 2004 | 05:20 PM
93supercoupe's Avatar
Default Re: (Copenhagen Honda)
I want to know how much oil pressure and volume the head is suppose to get b/c im tapped from my oil press. switch and i want to make sure its not starving
Old Oct 22, 2004 | 05:49 AM
Default Re: (93supercoupe)
bump!
Old Oct 22, 2004 | 02:28 PM
AzG35's Avatar
Mine is 15-20psi at idle depend how hot the motor is and how old the oil is. At max my motor see 75-80psi
Old Oct 27, 2004 | 07:36 PM
Default Re: (AzSi22)
bump
Old Nov 14, 2004 | 07:42 AM
swaytec360's Avatar
15 20psi at idle and around 85psi at wot
Old Nov 14, 2004 | 07:47 AM
mmuller's Avatar
Mad Scientist
Default Re: (swaytec360)
15-20 at idle, 70-75 at 3k rpms
Old Nov 17, 2004 | 11:16 AM
99lsvtecauto's Avatar
15-20psi @ idle 3000-5000 rpms 55-75 psi
Old Nov 19, 2004 | 11:06 AM
Insane Beast's Avatar
15-20 at idle.
85+ at and above 3500 RPM
Gsr Head
B18A block
Gsr crank&rods
PCT pistons.
TylerC161
Jul 5, 2007 09:47 PM
AsSanitySlipsAway
12
Aug 27, 2006 09:55 AM
AsSanitySlipsAway
12
Aug 18, 2006 06:29 PM
zexifiedlude
Jul 2, 2006 07:18 AM
Bloodwynch
Jan 22, 2002 10:18 AM
