h22a in a ek coupe???
same as in a eg. Some may say it's too much weight and the engine is tilted back. you'll have to do some suspension tweeaking to get soem decent ahndling out of it. It willl be fast in a straight line though. You will need a mount kit from Hasport or HCP and you will need custom axles to use the prelude intermediate shaft and you will need to do some cutting to fit the shifter and cables into inside of the car. you will need 92+ lude or 90+ accord shifter adn cables.
well there is a lot more to this swap and it's 5 am so i dn't want to righ anymore but do a search there is a lot of info out there.
later jesse
later jesse
UMMM well actually hasport doesnt have the kit out yet. I talked to the guy that owns it (i think his name is jermy or jerry)and he is building a b18c to dyno it and then sell it. he said that after that is done the H22 kit will begin. He also mentioned it to me that SCC mag will come out with the full story on it but that it should be out in JAN. AND he said that AC is a possibility. I was pleading this with him because i need ac = phx. so lets keep our fingers crossed.
