valve adjustment problem
Old Oct 14, 2004 | 12:14 PM
steve_meyer's Avatar
Default valve adjustment problem
Went to adjust my valves today, cyl1 and cyl2 went fine, but on cyl3, the exhaust side is way too tight, even with the adjustment screw loosened all the way, not even the .005 will fit Any ideas? Already tried searching, didn't find anything relevent...
Old Oct 14, 2004 | 01:15 PM
SpdFrk's Avatar
Default Re: valve adjustment problem (steve_meyer)
So wait. You placed the cam gears at TDC and did cyl.1 Then you turned the cam gears 90 degress counterclockwise and then did cyl 2???
Kamin's Avatar
Default Re: valve adjustment problem (SpdFrk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpdFrk &raquo;</TD></TR><TR><TD CLASS="quote">So wait. You placed the cam gears at TDC and did cyl.1 Then you turned the cam gears 90 degress counterclockwise and then did cyl 2??? </TD></TR></TABLE>
probably not, thats why his numbers are fucked up seriously. .
Old Oct 14, 2004 | 01:18 PM
SpdFrk's Avatar
Im thinking thats what he did. Hes probably got the gears at BDC and thats why he cant fit the feeler in cyl.3 on the exhaust side. At BDC you should be at cyl. 4.
Old Oct 14, 2004 | 01:30 PM
TekSI's Avatar
make sure to read carefully how to do a valve adjustment. like other said, cyl 1 at TDC on cam gear(or other method of finding TDC), rotate cam gears 90° CC, or crankshaft 180° CC(i believe), do cyl 3, then repeat rotation, cyl 4, repeat, cyl 2. use your distributor rotor as reference as well, it is supposed to contact the wire for that cyl which you adjust
rdssk8rcs1
Nov 20, 2007 08:29 AM
CPR
Jan 20, 2006 09:06 PM
MattD@Stoptech
Apr 9, 2004 07:26 AM
94GSRNewbie
Jul 26, 2001 11:06 PM
