Another idling issue! Help!
Old Oct 14, 2004 | 10:37 AM
luda98's Avatar
Default Another idling issue! Help!
Hey, 94 integra w/ ls vtec. (B18b, GSR head&intake, crower402s, portflwo v/t) The car starts ok but will not idle on its own! I've tried raising the idle (via the screw), cleaned the IACV, checked tension on the throttle cable, timing is perfect.....ARRRGGGHHH! (frustrated DSM guy working on a honda, sorry!) Does anyone have any Ideas??? I've read almost all the archived threads about low idle, poor idle, ect. Even went through trouble shooting sections of the Acura dealership manual. Any ideas guys?
Old Oct 14, 2004 | 11:05 AM
luda98's Avatar
Default Re: Another idling issue! Help! (luda98)
Bump
Old Oct 14, 2004 | 11:09 AM
luda98's Avatar
ah...rooking for help from you honorable Honda massa' techs (bump )
Old Oct 14, 2004 | 06:44 PM
boosted k20's Avatar
when i installed a set of crower 403 cams (mine was for non-vtec B18B motor) my idle was unstable. whenever i hit the throttle and let off, the car would drop the rpms really low and sometimes stall out. i fixed the problem by buying a B&M FPR and uping the fuel pressure, tuning this new fuel pressure with an SAFC, and also rasing the idle screw. if i were u i would try to raise the idle screw some more. on my car, the screw was hard to turn and when it did turn it only turned a little bit. i thought that this was the max position, but i could have turned it more. i needed to get more grip onto the idle screw so i took a screw driver and placed it on the screw, then hammered the screw driver on the the screw in order to get more grip. Do n this allowed me to turn the screw some more and the idle has been fine since.
Old Oct 17, 2004 | 11:28 AM
luda98's Avatar
Default Re: Another idling issue! Help! (boosted k20)
Thats a good thought, i think i have a FPR somewhere. At this point i'm almost just considering the stock cams...lotsa little issues in tha past few days. having random knock sensor codes too. thanks for the idea, may try that.
b_serious
Feb 8, 2006 05:42 PM
luda98
Oct 14, 2004 07:05 PM
Btothe3rdDegree
Jun 26, 2003 09:08 PM
GSRwBOOST
Jan 10, 2002 11:19 AM
