D16Z7 2 O2 sensors
Old Oct 14, 2004 | 10:33 AM
StrikerX's Avatar
Default D16Z7 2 O2 sensors
are there two O2 sensors on the D16Z7. gotta a friend with an LX that just had a 98 ex engine put into his car. looked up the specs of the 98 ex and it says it comes with a D16Z7 motor. guessing because its OBD2 maybe thats the reason for the 2 O2 sensors?
Old Oct 14, 2004 | 10:34 AM
EX-T's Avatar
Default Re: D16Z7 2 O2 sensors (StrikerX)
Never heard of a Z7...
The '96-'00 LX/DXs came with a D16Y7, nonVTEC...
Old Oct 14, 2004 | 10:54 AM
StrikerX's Avatar
Default Re: D16Z7 2 O2 sensors (DSeriesBKilla)
this site must be wrong then http://www.geocities.com/chipm....html
Old Oct 14, 2004 | 12:36 PM
StrikerX's Avatar
ok found it, its D16Y8 and is obd2, question is if the header has only the secondary O2 sensor mount that is under the engine, were would we fabricate a hole to mount the primary O2 sensor. its for a DC sport 4:2:1 one piece header.
Old Oct 14, 2004 | 12:38 PM
mike1114's Avatar
You can drill a hole and tap it for another o2 sensor, I think another way is to wire the first o2 to the second so it will not throw a CEL but I think the car might not run right cause it reads the difference between the 2 sensors.
Old Oct 14, 2004 | 12:40 PM
StrikerX's Avatar
Default Re: D16Z7 2 O2 sensors (mike1114)
wear would the hole need to be drilled?? looking at the pic from dcsports.com
SpoonEk253
Mar 22, 2006 06:10 PM
aaronblake98
Feb 15, 2004 04:20 PM
Hatebreed215
Mar 9, 2003 08:11 PM
Qwikrex
Jul 31, 2002 09:53 PM
