new extended wheel studds how to?
Old Oct 14, 2004 | 08:12 AM
dj_seloe's Avatar
Default new extended wheel studds how to?
got some new ARP extended wheel studds
just wounder if i need any special tools for this job?
and if somebody can give me some pointers on putting them on (with out grinding part of the studd?)
thanks alot.
Old Oct 14, 2004 | 08:13 AM
JDMallTHEway's Avatar
Default Re: new extended wheel studds how to? (dj_seloe)
use a hammer and knock the old studs out. put the new ones in, and tighten a wheel onto them, this will put them in place.
Old Oct 14, 2004 | 09:10 AM
Solscud007's Avatar
I remember there was a someone who wrote a pretty decent how to on this but I couldnt find it.
You will need a hub puller. and possible a slide hammer. at Kragen it costs 180. deposit to rent it for 6 bucks a day. The rear discs you may not need to take the hub off but i think it might make things easier. I too will put extended wheel studs on my car. but I have a tech day with my car club soon so i will wait to have access to a real garage. hehe
Old Oct 14, 2004 | 10:18 AM
dark Sol's Avatar
Default Re: new extended wheel studds how to? (Solscud007)
i did mine a little differently
i used a socket the same size as the hub to beat the hub out then knocked out the old studs and gently tapped the new one's in place about a quarter of the way in
then i very carefully put the hub back in the spindle by inserting an axle into the hub and using an impact to tighten the axle nut and pull the hub back in plce
Old Oct 15, 2004 | 07:45 AM
dj_seloe's Avatar
Default Re: new extended wheel studds how to? (dark Sol)
thanks for all thre replys guys
at least now i have an idea how long this will take..
keep it comming..
dre2day
Feb 16, 2008 07:56 AM
hamburgler
Sep 8, 2005 06:20 PM
ActiveAero
Sep 21, 2002 01:02 AM
Tyson
22
Jul 13, 2002 03:45 PM
