Exhaust problem (Apexi Dunk
Old Dec 16, 2001 | 08:23 PM
cbaLoy's Avatar
New User
Default Exhaust problem (Apexi Dunk
I just installed an Apexi Dunk catback exhaust 2 days ago. Everything went fine except for this rattling noise. I checked the piping and I saw that it was too close to the heat shield under the car, so I took it off. The noise decreased but there is still a rattling noise around 3000-5000rpms on 1st and 3rd gear. Does anyone know what the problem might be? Is the piping interfering with my shifter? help... The noise is killing me!!
Old Dec 16, 2001 | 08:54 PM
PolySquared's Avatar
Default Re: Exhaust problem (Apexi Dunk (cbaLoy)
hmmmm.... I have a 00 Gsr with the apexi dunk cat back exhaust also, but I dont have any problems with it. I removed my heat shield also.
Old Dec 17, 2001 | 07:45 PM
willyb94's Avatar
New User
Default Re: Exhaust problem (PolySquared)
What exhaust heat shield did you remove. If you didn't remove both (by cat. and by gas tank) I' d check that out. Also check out all the bolts to make sure they're on tight. LOL
Old Dec 18, 2001 | 07:24 AM
cipherpimp's Avatar
New User
I got my Dunk installed in the beginning of October, and about 2 days afterwards, I heard a rattling noise, but mainly when I was turning. I didn't do anything, and it's gone away.
Old Dec 18, 2001 | 07:47 AM
madchiller's Avatar
Premium Member
25 Year Member
Default Re: Exhaust problem (willyb94)
i wouldnt remove the one above the cat, just seems like yer asking for something. what i was told to do is get some of those metal clamps (kinda like zip ties) and time them around the cat and the heatshield, they are like ~$2 at home depot. should stop your rattling! :D
Old Dec 18, 2001 | 09:02 AM
Default Re: Exhaust problem (FuknGSR)
Oh man, i removed my heat shield. Is there anything bad about that? Someone told it just helps reduce heat to the cat and avoid heat coming into the car.
Old Dec 18, 2001 | 02:24 PM
tonydatyga's Avatar
that one keeps the hot cat from lighting dried leave or grass on firein case you park on them.
ooosorio
Honda Civic (2001 - 2005)
Aug 26, 2015 09:25 PM
ih8speedbumps
Jan 4, 2014 03:17 AM
Toddgsr
Jun 1, 2004 11:37 AM
tolowhb
17
Apr 2, 2003 07:36 PM
4drRacer
Oct 2, 2002 09:47 AM
