Integra Brake Swap Question
Old Oct 13, 2004 | 09:44 PM
SpydiR's Avatar
Default Integra Brake Swap Question
First off, I've already done a search, but found a lot of mixed opinions. I've got a 1" DC m/c, booster, and knuckles, swapping all four corners on a '93 CX without ABS. What prop valves will work for this application? I've heard that it must be from a 94-95 RS, but I also heard that if it says '4040' on it it's all good. Will a '4040' valve from a DA integra work? Also, what is the 4040 all about? is it a part number or the brake bias?
Old Oct 13, 2004 | 09:51 PM
dantastic's Avatar
Default Re: Integra Brake Swap Question (SpydiR)
4040 is not the proportion percentage... its a part #. the proper prop valve is a 4040 from a non-abs teg, DA or DC gen. i have a 3040 prop valve (4 wheel disc, but 9.5" in the front) from a DA, and i'm running 94 gsr brakes all around witha 15/16 MC. works fine also.
Old Oct 13, 2004 | 10:13 PM
SpydiR's Avatar
Default Re: Integra Brake Swap Question (dantastic)
Thanks for the info man, that kind of clears things up. One more question: I hear that you have to 'change the mounting bracket' if you use the valve from a DA. Will my stock bracket work?
Old Oct 13, 2004 | 10:17 PM
. o 69 o .'s Avatar
nope, stock bracket definitely wont work. you will have to fab something up, but its not a big deal, once thr valve is in there, you will see what you have to do
Old Oct 13, 2004 | 10:18 PM
SpydiR's Avatar
Default Re: Integra Brake Swap Question (B16B)
well if it's that simple I'm sure I'll figure it out. Thanks for the help guys!
Old Oct 13, 2004 | 10:31 PM
92RED Hatch's Avatar
I recently did an itr 5 lug and brake swap on my 92 hatch...and as far as the proportioning valve goes order one for a 95 civic si non abs. It is a direct replacement had will keep life a lot easyier when replacing it so you won't have to bend any lines in that area. And of course it looks the exact same as the one you got, but proportions different amtounts of fluid to the rear...You can tell by looking at the part numbers on the actual prop. valve...you can order it from here
http://www.hondaautomotiveparts.com/
Old Oct 13, 2004 | 10:45 PM
. o 69 o .'s Avatar
Default Re: Integra Brake Swap Question (92RED Hatch)
95 si uses a 40/30....
if you are running integra disc all around, use what an integra came with... 40/40
Don't mickey mouse it
10cjennings
May 14, 2014 06:01 PM
GReddy SI
Apr 2, 2009 09:09 PM
timmy0tool
Dec 18, 2007 12:49 PM
yellowjdmcrx
Jun 28, 2006 09:05 AM
jdmcivicferio
Feb 1, 2003 10:50 AM
