Honda S2000 Honda S2000
Going to build custom turbo...
Old Oct 13, 2004 | 08:45 PM
GroovyNeilNeil's Avatar
Default Going to build custom turbo...
and need to know the best cost efficient way to lower the compression. Any suggestions?
Old Oct 13, 2004 | 11:59 PM
papa5murf's Avatar
Default Re: Going to build custom turbo... (GroovyNeilNeil)
headgasket.... but ummm...... do the job right.. and spend the money...the first time around.. otherwise you'll be spending a lot more money in the long run with repairs and engine rebuilds.
Old Oct 14, 2004 | 10:59 AM
Turbo2k's Avatar
Default Re: Going to build custom turbo... (03s2kblue)
check out http://www.inlinepro.com they have the head gasket
Old Oct 14, 2004 | 12:31 PM
ChrisRicketts's Avatar
Default Re: Going to build custom turbo... (Turbo2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03s2kblue &raquo;</TD></TR><TR><TD CLASS="quote">headgasket.... but ummm...... do the job right.. and spend the money...the first time around.. otherwise you'll be spending a lot more money in the long run with repairs and engine rebuilds. </TD></TR></TABLE>
--------I'm with this guy.
Old Oct 14, 2004 | 01:13 PM
The Tea-father's Avatar
Default Re: Going to build custom turbo... (ChrisRicketts)
go out and get a set of low compression piston. spend the money and get good computer system. car will last for long time. if you don't want to spend the money on those piston, go with a supercharger application!
Old Oct 14, 2004 | 01:24 PM
WowOzYouRock's Avatar
GroovyNeilNeil LOL .. OMG this kid ask to many qustions LOL ... do you even know how much its gonna cost you to boost ur kaa? if you dont got 10 g then might aswell put weed blower for now
Old Oct 14, 2004 | 01:52 PM
Default Re: Going to build custom turbo... (oneloudcivic)
Yeah well this kid has a better car than a civic. Anyways...3 of my friends build turbo set ups all the time. They recommended I lower the compression and I wanted to see what S2000 owners thought would be a good way to do this. This is a message board right? Questions are allowed here...or at least I thought. My friends told me that they wouldn't charge me for building the manifold or any of the pipe bends...I'd just need to buy the pipe. I'm going with stainless steel and probably 2 1/2-3" downpipe. They said I wouldn't have to rebuild the bottom end since I told them it's a daily driver and I'd only be running 5-7 lbs of boost. They said I needed larger injectors also. Anybody have suggestions for injectors?
Old Oct 14, 2004 | 02:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GroovyNeilNeil &raquo;</TD></TR><TR><TD CLASS="quote">Yeah well this kid has a better car than a civic. Anyways...3 of my friends build turbo set ups all the time. They recommended I lower the compression and I wanted to see what S2000 owners thought would be a good way to do this. This is a message board right? Questions are allowed here...or at least I thought. My friends told me that they wouldn't charge me for building the manifold or any of the pipe bends...I'd just need to buy the pipe. I'm going with stainless steel and probably 2 1/2-3" downpipe. They said I wouldn't have to rebuild the bottom end since I told them it's a daily driver and I'd only be running 5-7 lbs of boost. They said I needed larger injectors also. Anybody have suggestions for injectors?</TD></TR></TABLE>
HAHAHAH i have S2000 also HAHAHAH i would'nt post here if i dont have one moron ...
Modified by oneloudcivic at 11:57 PM 10/14/2004
Old Oct 14, 2004 | 03:00 PM
You call me the moron...however it is YOUR screen name that says Civic. An assumption can be incorrect. Do you have a turbo S2000? I'm not trying to be smart or anything, I would just like advice...
Old Oct 14, 2004 | 08:11 PM
evil vapor's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneloudcivic &raquo;</TD></TR><TR><TD CLASS="quote">
Modified by oneloudcivic at 11:57 PM 10/14/2004</TD></TR></TABLE>
how much longer do you want to post here?
Old Oct 14, 2004 | 09:33 PM
papa5murf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GroovyNeilNeil &raquo;</TD></TR><TR><TD CLASS="quote">They said I needed larger injectors also. Anybody have suggestions for injectors?</TD></TR></TABLE>
the size of the injectors you're going to get are going to vary on how much power you want to push out... main thing.. just make sure you get it tuned properly... but like i said in my first post....
Old Oct 14, 2004 | 10:35 PM
i IMed him about it and i think he get it yo
Old Oct 17, 2004 | 12:25 AM
ATF Kuk's Avatar
if u are going to run low boost, u "dont have to" lower ur compression. just make sure u use a good engine management system.
if u really want to lower ur compression, i would call cometic and look into a custom headgasket.
P@@RB@Y
Dec 17, 2005 04:05 PM
RedEK99
Apr 11, 2005 11:43 PM
deviusdragger
Jul 29, 2004 02:16 PM
BOOSTEDcivicB18C1
Sep 10, 2003 08:37 PM
Arch-Angel
Jul 11, 2003 12:56 AM
