nsx brake conversion
So i saw a picture of a type r with nsx brake calipers on it what would be required to put them on my r? also would it really be that big of improvement from my stock brakes. Does anybody know if they just bolt up any info would be appreciated??
thanks in advance.
thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acurar »</TD></TR><TR><TD CLASS="quote">So i saw a picture of a type r with nsx brake calipers on it what would be required to put them on my r?</TD></TR></TABLE>
Search?
https://honda-tech.com/zerothread?id=766629
>Search Results
Your search for nsx brakes returned 5 results.
» Search Results
Your search for nsx returned 85 results.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acurar »</TD></TR><TR><TD CLASS="quote">also would it really be that big of improvement from my stock brakes.</TD></TR></TABLE>
Depends on what you mean by improvement. They will provide better modulation.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Does anybody know if they just bolt up any info would be appreciated??
thanks in advance.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=743266 - NSX
https://honda-tech.com/zerothread?id=720430 - NSX
https://honda-tech.com/zerothread?id=610835 - NSX
https://honda-tech.com/zerothread?id=482434 - NSX
https://honda-tech.com/zerothread?id=291367 - NSX
https://honda-tech.com/zerothread?id=239844 - NSX
https://honda-tech.com/zerothread?id=349039 - NSX/Legend
https://honda-tech.com/zerothread?id=409290 - Legend
Search?
>Search Results
» Search Results
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BDBGoalie1982 »</TD></TR><TR><TD CLASS="quote">that clearance as tight as it looks?</TD></TR></TABLE>
nope, plenty of room
It's bad enough that people don't search before asking a question that has been kicked around a thousand times, but this is getting ridiculous. Yoshi and 1GreyTeg all but spoon-fed the information to you above. If you still have questions after reading the information that they searched and found for you, then by all means ask away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Punkaddic »</TD></TR><TR><TD CLASS="quote">what do i need for the nsx caliper conversion ?? Just caliper and pads ?? </TD></TR></TABLE>
I cannot help you if you refuse to help yourself.
I read a lot of these threads, I mine as well put in my question:
If putting nsx calipers on a 94 gsr, can I use the gsr caliper brackets or do I need the type r, nsx, or legend brackets as well as drill the teg or legend rotor to 4 lugs.
a12rnulfo
Nov 21, 2006 12:27 PM
