throttle body spacer
Old Oct 13, 2004 | 07:02 PM
honda94civicturbo's Avatar
Default throttle body spacer
i need some advice i was looking at this throttle body spacer for a 94 1.5l civic and wondering if it actually gives some hps or if it is worth buying i mean i heard that they put them on some mustangs and other bigger engine motors and they do give some performance what about on a civic? can anyone help? thanks phil
Old Oct 13, 2004 | 09:08 PM
JDMallTHEway's Avatar
Default Re: throttle body spacer (honda94civicturbo)
i have a 65mm throttle body on mine which is 25% larger than stock, the gain from a larger throttle body really depends on what other mods you ahve, intake manifolds and cams help, while turbos give big gains. I find that mine works great, and gives me some high rpm power. be careful what size you get, 70mm and larger usually sacrifice low end power depending on other modifications.
Old Oct 14, 2004 | 09:25 AM
Default Re: throttle body spacer (JDMallTHEway)
is it a throttle body spacer or throttle body becasue im asking about the spacer a one inch spiral spacer that goes between the throttle body and intake manifold?
Old Oct 14, 2004 | 09:42 AM
splitime's Avatar
http://www.outlawengineering.com/index.html
Their heatshield kit actually works somewhat like a spacer also. I'm installing this kit next week on my car mainly for the heatshield qualities.
Very nice kit btw, everything they say it includes.. it actually does. Nice pieces also, for 100 bucks its hard to go wrong. Spacer/heatshields + gaskets + extended hardware (including plastic washers for studs on IM.
Old Oct 14, 2004 | 12:34 PM
Ghetto Civic HX's Avatar
I love to drive
Default Re: throttle body spacer (splitime)
unfortunetly, I don't think any bolt-ons will add too much hp to your engine. I would just concentrate on the standard I/H/E.
Old Oct 14, 2004 | 12:58 PM
91civicDXdude's Avatar
TB spacers worked on older v8 cars becuase it effectively lengthens the intake, making more low end torque. on a honda you want the exact opposite.. you want a short fat intake.
they are a worthless gimmick, much like the amazing gas saving tornado!!!#@#
EJtypeR
Jun 17, 2015 08:01 PM
Gsrsi
Nov 22, 2011 07:39 PM
tegSB85
Nov 17, 2005 05:50 AM
Fink2iCe
Aug 20, 2004 10:50 AM
