93 Ex Speedo not workin :(
From: Your mommas bed, that might be true too ..., So Cali, USA
My Speedo isnt workin, and my rpms work a lil its goes up to 4k and restarts again from 1 ? what is wrong ???
Have you done anything with your cluster? Or ECU? Pull the cluster out and make sure the back of the cluster is clean and none of the wires or harnesses are damaged. Oh, and you can be honest if you have done something with the cluster...I have screwed up a couple of them myself.
I took the cluster out today nothin seemed wrong i plugged them in good still my tach only goes up to 4k, i still press on the gas it just stays at 4
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bgoetz »</TD></TR><TR><TD CLASS="quote">check the speed sensor in the back top of the tranny</TD></TR></TABLE>
VSS, it's on top near the back. it has two bolts, and it's round. goodluck
If you have a friend with a 92-95 swap VSS's with him - put yours on his car and vice-versa to see if the problems can be duplicated.
