d15b in 96 civic... change ecu?
Old Oct 13, 2004 | 10:19 AM
jamesyoung28's Avatar
Default d15b in 96 civic... change ecu?
96 honda civic hx with a d15b vtec
the cel light is on it shows p1336 (crank sensor).. the crank sensor is not hooked up, cause the older engine has no place for it.. if i change the car to an obd1 ecu will the cel light go away? like just doing the harness adapter and putting in a p28 or something......?
Old Oct 13, 2004 | 11:54 AM
BigIslandBoi's Avatar
Default Re: d15b in 96 civic... change ecu? (jamesyoung28)
hey bro I was just woundering if you wanted to pick up a P72 (GSR OBD2) ecu for $120.... just saving you some time and money...if not you will have to go and repin the ecu harness clip and connect it to the knock sensor...have fun with that...and the D15B ecu sucks, it has a slow response... well let me know if you want the P72...
Old Oct 14, 2004 | 09:13 AM
Default Re: d15b in 96 civic... change ecu? (BigIslandBoi)
would i still get a cel light? i dont want to hook up the knock sensor so i thought i would have to put in an obd1 ecu.
stenger
Engine Management and Tuning
Sep 18, 2015 08:15 PM
jonyi27
Jul 1, 2013 09:29 PM
shytdoode
May 20, 2009 03:41 PM
shoklid
14
Jan 15, 2009 09:10 AM
216.226.142.95:27016
Jan 8, 2003 11:45 AM
