Where can I find this material...("Aqua Foam"??)
Old Oct 13, 2004 | 05:08 AM
CompressionFed's Avatar
Default Where can I find this material...("Aqua Foam"??)
I recently heard someone speaking of a product that you can shape, then wrap fiberglass, or CF, or whatever over it, let it dry, and then run it under water to disolve the origional "Aqua Foam" material.
I don't know if that is the name of the material, but I was told it is very expensive. Please give me the correct name, and where I can buy it.
Thanks!
Old Oct 13, 2004 | 01:36 PM
nonsense's Avatar
Default Re: Where can I find this material...("Aqua Foam"??) (CompressionFed)
the technique is called "lost foam molding". You can use regular foam and some accetone to dissolve it. I have also heard of the stuff that is water dissolvable, but I think it's expensive and hard to work with
here's a link with some details about it
http://www.favonius.com/soarin...m.htm
EDIT . . . . . . more info:
it's called aquacore
I knew I saw another post about it:
https://honda-tech.com/zerothread?id=999658
Old Oct 13, 2004 | 02:10 PM
BROOD's Avatar
Default Re: Where can I find this material...("Aqua Foam"??) (nonsense)
Yep, it is called AquaCore. Works great but it is not cheap though.
Old Oct 14, 2004 | 04:30 AM
Default Re: Where can I find this material...("Aqua Foam"??) (BROOD)
Thanks guys, thats what I was looking for.
NVturbo
May 15, 2008 07:24 PM
tom_l
Jun 14, 2005 04:04 AM
MiraiZ
Oct 14, 2001 02:17 PM
