Possible problem with FPR gauge
Wassup guys,
I recently notice that my FPR gauge on my car stays at 40 psi when the car is turned off. Is this a sign of a bad gauge? Normal thinking would say it should go all the way down to 0 correct? The gauge does fluctuate higher when i hit the gas. The motor is a B18C1 if that matters and i am using the stock GSR fpr and gauge.
Modified by spankey167 at 12:01 AM 10/13/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">mine stays at pressure too for a while after i shut off the car. its normal b/c the fuel system is still pressurized after you stop the engine</TD></TR></TABLE>
Thanx
Anyone else with the same thing?
Thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @ries »</TD></TR><TR><TD CLASS="quote">What brand of fp gauge do you have? </TD></TR></TABLE>
its just the stock gsr one
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by @ries »</TD></TR><TR><TD CLASS="quote">no.... the fuel pressure gauge? what brand is it?</TD></TR></TABLE>
you are talking about the psi gauge right? If there is a type of brand for the type of gauge for a stock gsr. Then i dont know. Its just a stock one. My friends stock gsr has the same one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spankey167 »</TD></TR><TR><TD CLASS="quote">
you are talking about the psi gauge right? If there is a type of brand for the type of gauge for a stock gsr. Then i dont know. Its just a stock one. My friends stock gsr has the same one. </TD></TR></TABLE>'
Are you saying that you have a stock Fuel pressure regulator on your GSR?
@ries I think is asking about the gauge that you added to your fuel system to give you a reading. That portion is aftermarket, like the picture above.
If you have a stock fuel pump, then this is completely normal as there is a check valve in the pump that helps to maintain the pressure when the car is shut off.
Ok guys when i checked my gauge in the morning... It went to 0 psi. So you guys were right... I guess there is residual pressure that stays for a while. But i guess it then goes away
