will this engine combo work
i can get a 98 y8 auto out of the junkyard for 75 bucks. my d15b vtec is on its last legs. so can i use the intake manifold and cam out of the d15b in the y8. is there any reason not to use the y8 auto. i mean is there a difference between auto and manual as far as internals. it has the y8 intake manifold but its auto. so thats out of the question. but since the cam is out of the d15b it should make more power than the y8 cam right, plus its a 1.6 compared to a 1.5. anyones input is appreciated.
oh im not gona use the auto tranny, i already have a 98 y8 5spd tranny in there. i just wanna know if this combo will make any more power than my d15b vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WEST SIDE »</TD></TR><TR><TD CLASS="quote">
i had the same motor your talking about in a ef and ran mid 14's all day with basic bolt ons.</TD></TR></TABLE>
are you talking abou the y8, or the d15b vtec?
or what would the compression ratio be if i used an a6 bottom end with my d15b vtec head. i just know i gotta figure something out on this bottom end, its about let go.
ya, all the research i did said that the d15b cam was just under the comp/zex 59300. like if you put the 59300 in place of the d15b cam, youll only gain like 1-2 horse. well...everything i found on here suggests that. but what about using different bottom ends, like an a6 or even a sohc non-vtec zc bottom end with my head. cause the head on the d15b vtec is exactly the same thing an z6 head, all the markings and everything, just the cam is different. i just want a pretty potent combo and i need a new bottom end.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by a1320honda »</TD></TR><TR><TD CLASS="quote">but i cant put a sohc vtec head on the dohc bottom end.</TD></TR></TABLE>
No you cant. But i think the guy was talking about getting the SOHC integra motor (atleast i hope thats what he was talking about) Sorry i dont know the code for it though.
You should rent out a dyno for the day and do a run with the stock y8 and then put the d15 cam in there right then and there and see if it makes more power over the stock y8. I would really like to know this incase if i go back to D series in my next car.
when did the teg have a sohc motor in it. not even the 86-89 tegs had a sohc. if there was a dyno within 450 miles of here i would. but it kinda suck as far as thats concerned.
and sorry, im not trying to start a fight or anyhting, i just have never heard of a teg having a sohc
Aaron Cayabyab
Jun 29, 2012 09:57 PM
TheAutoboxer
Apr 26, 2003 03:21 PM
