need help with weird transmssion/clutch problem....
1994 civic si hatch, we had just put in a built engine and new tranny, started it up and backed it up before we realized we hadnt topped off the tranny oil...so we drained the old stuff out (maybe 1500 miles on it minus the spilled stuff from pulling the engine out). then refilled with 2 quarts of syncromesh. took it for a drive all was well cept for reverse would grind a little. let it sit for a few while idling then went to drive aroudn the block again, and it wouldnt go into gears 1-5....only reverse with a lot of effort and grinding. so we cleed the clutch with a small vacuum pump. adjsuted the pushrod.
same old stuff. when the car is off it goes into all gears.
the clutch we put in is a brand new Competition Clutches Strip Clutch.
anyway if anyone has suggestions im all ears..cause im about to drop the tranny int he morning and i DONT want to.
Johnny Cochran
May 22, 2006 12:40 AM
J-Brooks
Dec 17, 2002 10:23 AM
