LS crank in GSR
i have a gsr turbo and wanted to put in an ls crank and rods but not gonna sleeve. i searched and foudn problems in crank hitting the oil squiters. can they be removed and be alright to up to 10 11 pounds with stock gsr pistosn and ls rods?debating if i got money to possibly run like forged pistons and like forged ls rods on the ls crank. i want forged pistons and rods but gotta see if i got money to? whats ur thoughts on this set up
Stroking is always good, but you may want to lower the redline with all that boost and stroke. That's some stress on the poor thing, you know... But if you want 10 or 11 pounds, you'll hear from everyone and their mom that forged is the safest way to go. Stock LS rods and LS pistons (don't run GSR pistons, Sack got it right) should be ok that high, but you'll probably want to dish for the extra boost.
It's all good, whatever you want. But you need to have the oil squirters removed or bent (I think you can bend those little ******) for the LS crank. And you should know, LS rods with an LS crank. GSR pistons fit LS rods, but LS pistons will get you lower compression. Whatever floats your boat, dude...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Prof. Crumb »</TD></TR><TR><TD CLASS="quote">i have a gsr turbo and wanted to put in an ls crank and rods but not gonna sleeve. i searched and foudn problems in crank hitting the oil squiters. can they be removed and be alright to up to 10 11 pounds with stock gsr pistosn and ls rods?debating if i got money to possibly run like forged pistons and like forged ls rods on the ls crank. i want forged pistons and rods but gotta see if i got money to? whats ur thoughts on this set up </TD></TR></TABLE>
crank may hit the squirters, but you would have to lay crank into block and see how much they will hit. You can bend them to clear crank throws....its been done before.
using a ls crank with your p72 pistons will give you a compression increase of about .2 , so it would be around 10.2
if you use pr4's comp. will be around 9.7 ish
so use ls rods, pistons and crank if sayign stock, and im sure ill probably go with forged rods and pistons so but thats not a def, and is this good to run with turbo also. any more comments will help
turbodelsolb16a2
Feb 7, 2010 07:57 AM
