EX harness????
thats because the secondary o2 plugs into the chassis harness, on the non-vtec models(such as dx and lx) they plug into the engine harness, but on the y8 it's the chassis
usually the plug goes inside the cabin of the car in front of the shifter portion. there should be a plug in there if your car was equipped with 2nd 02. otherwise you will need to run to ecu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ki11a8ee »</TD></TR><TR><TD CLASS="quote">how would u get the chassis harness cause i have the same problem too? and how do u plug it to the ecu?
thanks
You can get them from importautosalvage.com for about 100 bucks. However..it runs throughout your entire dash, so take a good look and realize that your entire dash has to come apart to replace it.
thanks
okay but explain this to me though. If you're saying the secondary O2 harness is on the chasis, Where does the wires run, to get into the ecu? Cause as of right now, My harness is all plug into the ecu. So if this is the case, then how does the EX gets its secondary O2 signal into the ECU?
When I took out the harness from the EX, I don't remember disconnecting and any plugs from the engine harness that connects to the chasis harness.
nello a.
Dec 24, 2008 12:20 AM
hx-b16hybrid
Jul 1, 2005 10:53 PM
