oil leek
Old Oct 12, 2004 | 06:18 PM
DOHC_EG6's Avatar
Default oil leek
i got a lsv b18b block with type r head. i got a leek between the block and the head.
Old Oct 12, 2004 | 07:05 PM
PLAN:B's Avatar
Default Re: oil leek (DOHC_EG6)
im sorry
Old Oct 12, 2004 | 07:06 PM
Ricey McRicerton's Avatar
Default Re: oil leek (PLANBmotorsports)
And the question is what?
Old Oct 12, 2004 | 07:08 PM
skunk2eg's Avatar
Default Re: oil leek (Ricey McRicerton)
a head gasket usually goes beween them....
Old Oct 12, 2004 | 07:11 PM
Deemeetree's Avatar
Electrician
Is it oil? Is it antifreeze? Is it beer? What exactly is leaking? Do you have a picture?
But as skunk2eg said, a headgasket is usually between the block and cylinder head.
Old Oct 12, 2004 | 07:16 PM
Default Re: (Dimi)
Headgaskets are for pussies. Just machine them to sit right agianst each other.
Old Oct 12, 2004 | 07:17 PM
skunk2eg's Avatar
Default Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Headgaskets are for pussies. Just machine them to sit right agianst each other.</TD></TR></TABLE>
+1
Old Oct 12, 2004 | 07:20 PM
PLAN:B's Avatar
Default Re: (skunk2eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunk2eg &raquo;</TD></TR><TR><TD CLASS="quote">
+1</TD></TR></TABLE>
Werd
Old Oct 12, 2004 | 08:53 PM
BauleyCivic's Avatar
Risky Business
Default Re: (PLANBmotorsports)
**** that...
JB Kwik that head on there and you can be driving around in 4 minutes!
Old Oct 12, 2004 | 09:12 PM
SOHCejcivic's Avatar
Default Re: (BauleyCivic)
a. leak&gt;leek
b. headgasket. if it's both oil and coolant (white foamy ****) you've got yourself a blown headgasket. are you sure it's not the valve cover gasket? is the leak above/below where the header bolts up?
^^i'm going with the jb weld. jb weld owns all!
Old Oct 13, 2004 | 03:52 AM
DOHC_EG6's Avatar
Default Re: (SOHCejcivic)
i just replaced my valve cover gasket. and its just oil.
milkmanLCA
Oct 5, 2008 07:55 PM
hondasport89
Aug 25, 2008 07:41 PM
motrayEG6
Sep 4, 2006 08:33 PM
RICE POLICE SIP
Apr 5, 2006 09:07 PM
walkerklondyke2000
Jan 12, 2006 10:11 PM
