why is my engine wet on top?
Old Oct 12, 2004 | 03:00 PM
GetCaughtDead's Avatar
Default why is my engine wet on top?
I'm not sure what it is or where it's coming from, but my something is blowing around pretty good in my engine bay. The underside of my hood gets black and wet, as well as my valve cover. The sides of my head are wet in some places, too, but I think it's just running down from the top. Almost seems more like coolant than oil, but it's definitely black. Where could it be coming from that it's all over both my hood and the top of my engine? I dunno if it matters, but I've got a 90 LS swap in my 91 CRX. I know I burn a quart of oil in about 2000 miles, and I'm losing coolant very slowly, but I never have any drips under my car when it's been parked for a while. Also, I've tried to watch it run, even revving pretty good, and I can't see anyting coming out from anywhere.
I'll see if I can't still take some pics on my busted camera card.
Modified by GetCaughtDead at 1:42 PM 10/13/2004
Old Sep 8, 2006 | 11:18 PM
EH2 on Steelies's Avatar
Default Re: why is my engine wet on top? (GetCaughtDead)
this is also happening to me.. strange how nobody else had this problem?.. help pls
Old Sep 9, 2006 | 03:28 PM
Brick Top's Avatar
we need good pics
Old Sep 9, 2006 | 04:32 PM
MR_FIX_IT's Avatar
ive gota 91 ls and i have the same problem. Dose it form arond ur oil cap?
Old Sep 9, 2006 | 04:51 PM
leeminho86's Avatar
Check the rubber gaskets that go under the bolts that hold the valve cover on...should be a rubber piece under a metal lid and a nut that goes over both of those. When I redid my head I forgot to use those gaskets and had the same problem...oil was squirting everywhere whenever I accelerated.
Old Sep 10, 2006 | 04:56 PM
Suck my DX's Avatar
Default Re: why is my engine wet on top? (leeminho86)
possible torn cv boot spewing grease everywhere
Old Sep 11, 2006 | 05:44 AM
Lewdin' Incognito's Avatar
Default Re: why is my engine wet on top? (Suck my DX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX &raquo;</TD></TR><TR><TD CLASS="quote">possible torn cv boot spewing grease everywhere</TD></TR></TABLE>
Be kinda hard to sling the grease all way up to the hood, wouldn't it?
Have you been losing oil, coolant, power steering fluid, brake fluid?
EDIT: Ok I reread your original post, sounds like you could have a pinhole in a coolant hose maybe. Then it wouldn't spray out until it was hot/pressurized.
You could try and fasten a thin sheet of cardboard to the bottom of your hood before you head out and that might help you localize where it is coming from.
Old Sep 11, 2006 | 08:01 AM
Suck my DX's Avatar
Default Re: why is my engine wet on top? (Lewdin' Incognito)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lewdin’ Incognito &raquo;</TD></TR><TR><TD CLASS="quote">
not really...ive had it happen to me and seen it on other cars as well
Old Sep 11, 2006 | 12:17 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
A hole in a axle boot will spray grease EVERYWHERE. Although it is obvious that it is grease by the thickness. You probably have a hole or a crack in a coolant line, or its not seated properly.
lemur1987
Oct 21, 2013 07:17 AM
Lithel
Oct 15, 2007 12:48 PM
Attaus
Apr 26, 2007 01:40 PM
GetCaughtDead
Oct 13, 2004 06:57 PM
ion_four
Apr 6, 2003 06:44 AM
