front lower ball joint noise...
Well i think a lotta of you heard that i put in new suspension....but my problem is this... before i put my coilovers in, i had a really loud squeking/grinding noise coming from pass. wheel area. I left it go since i was going 2 replace just about everything in the front. But it's still there after all new bushings, control arms, coilovers, etc. I'm almost 95% sure it's the lower ball joint and lower control arm making the noise. I took it apart today and greased everything hoping it would go away, but it came back
. The noise usually happens when i turn the wheels, start out, or stop....anytime a change in motion in the car....HELP!
yup, and it's horribly loud, it's embarrasing driving a 1/2 decent looking car sounding like pure hell
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rudeman85 »</TD></TR><TR><TD CLASS="quote">yup, and it's horribly loud, it's embarrasing driving a 1/2 decent looking car sounding like pure hell
LOL I've seen some of them pretty bad. Replacement is the best fix if their that noisy.
</TD></TR></TABLE>LOL I've seen some of them pretty bad. Replacement is the best fix if their that noisy.
Brand new tire rods, tie rod ends, EVERYTHING is brand new except lower ball joints, but i just went to expert tire, and here it's my brand new ball joints (camber kit) i just have to take it apart and grease that one. Sorry guys, i thought it was the lower one the whole time
. The guy sprayed some silicon spray on the top ball joint and it instantly stopped! Now i just have to grease it.
i had the same problem on my cb7(4th gen accord) whenever i turned the wheel and whenever i went over some small bumps and when i stoped hard i would hear this squicking noise. lol i hated it so much.
turned out to be the lower bolt joint. 100% sure
Well i grease the upper ball joint and cleaned it with a wire brush real good. It WORKED! but only for like an hour
Brand new ball joints too, made same exact noise before they were put in...what to do what to do
I have a really really light bit of movement in the the wheel, but 3 shops have just told me that my axle nut should be tightened down a little bit more. So i'm good there, and my upper joints are all BRAND NEW!
alscrx
29
Aug 10, 2021 11:23 PM
refpoman
Honda Civic (2001 - 2005)
Nov 17, 2013 04:09 AM
