Leaking and floor boards are puddles.
Old Oct 12, 2004 | 01:15 PM
Madrek's Avatar
Default Leaking and floor boards are puddles.
Ok last rain fall I had puddles in both my driver side and passenger side floor boards..People say I have a leaking windshield cowl. I took off all the pins and everything and tomorrow I will silicon everything up...Anyone have this problem and did sealing the cowl with silicon work? Can it be something else that is causeing a bad leak into my floor boards? Help me out and let me know if anyone experienced this problem before.. Thanks
Old Oct 12, 2004 | 03:09 PM
alotawatts's Avatar
Default Re: Leaking and floor boards are puddles. (Madrek)
Known problem for some Civics. Use a search engine (Google etc) on the topic. Check the firewall ....air plenum. Leaks can be hard to pinpoint because often water only moves in when you are at speed...
Old Oct 12, 2004 | 03:51 PM
nonsense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Madrek &raquo;</TD></TR><TR><TD CLASS="quote">Ok last rain fall I had puddles in both my driver side and passenger side floor boards..People say I have a leaking windshield cowl. I took off all the pins and everything and tomorrow I will silicon everything up...Anyone have this problem and did sealing the cowl with silicon work? Can it be something else that is causeing a bad leak into my floor boards? Help me out and let me know if anyone experienced this problem before.. Thanks</TD></TR></TABLE>
the same sh*t happened to my old DA . . . the seal between the cowl and the windshield was worn out.
Old Oct 12, 2004 | 05:10 PM
Madrek's Avatar
I will keep you guys posted if I can find the leak...
Barry Nagle
May 15, 2017 07:56 AM
CARflyGUY
Nov 22, 2006 08:10 AM
joker05
Apr 1, 2006 03:14 AM
b16pwrdeg
18
May 9, 2005 02:29 PM
Hybrid 350GT
Honda S2000
13
Jan 31, 2005 09:01 PM
