Engine wiring help? (b16a1)
Old Dec 16, 2001 | 12:25 PM
TurboMiata's Avatar
Default Engine wiring help? (b16a1)
Almost done with swap..... but we cant seem to find where two connectors go from the wiring harness. They are both green connectors, and there are 3 of them. One goes to Vtec selenoid, and the other two go...? (NOTE: they look JUST LIKE the vtec connector) One has one wire going to it, and the other has two wires going to it.
Any help would be greatly appreciated
Old Dec 16, 2001 | 03:10 PM
CoLJeW's Avatar
Default Re: Engine wiring help? (TurboMiata)
did you wire the oil preasure switch and the knock sensor.. and what about the second O2
Old Dec 16, 2001 | 03:51 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
one is for the extra O2 sensor, the one with the one wire only.
The other should have two wires, a blue and a black wire.
It goes on the oil press switch on the VTEC solenoid
The black wire goes to ground at the termostat housing ground, the blue wire goes to the ECU.
toxictom
Jun 15, 2017 10:42 AM
Diyracing2
Jul 17, 2006 11:52 AM
Bseriesy0
Sep 21, 2004 09:43 AM
blueskiesfade609
Apr 16, 2004 10:32 AM
AdamITR
Apr 26, 2003 01:28 PM
