need help wiring a 4 wire o2 sensor
Old Jun 15, 2017 | 10:42 AM
toxictom's Avatar
Icon6 need help wiring a 4 wire o2 sensor
Hey so ive got a ef hatch i swapped in a b20 and converted the harness to obd 1 my jumper harness has a plug with a bunch of wires running off ....
Wire Color Item Function:• Blue - P02SHTC - 02 Sensor Heater Control (02BLK Wire)
• White - PH02S - 02 Sensor Signal (02 WHT Wire)
• Violet - VTS - VTEC Solenoid Signal
• Gray - VTM - VTEC Pressure Switch Signal
• Green - IAB - Intake Air Bypass Signal
• Orange ? KS - Knock Sensor Signal
• Red or Pink (2) - IGP Power (IAB, 02, BLK Wire)
• Black or Brown - (3) -PG Ground - (SCS, VRM, 02 GRN Wire)
• Yellow ? SCS - Service Check Signal
this is the list of what the wires do...
I have a bosch/denso 4 wire o2 sensor and I found a diagram saying that the blue wire is signal the white wire is ground then the 2 black wires are heater. How do I wire this up?
hondateg10
11
Jan 28, 2009 04:35 PM
turboH22Aakkord
Aug 24, 2005 06:47 AM
CrxEDguY
Apr 28, 2005 09:46 AM
mf RENO
Oct 18, 2004 02:25 PM
