HELP WITH HEADER INSTALL ASAP...
Old Oct 12, 2004 | 11:07 AM
madlion's Avatar
Default HELP WITH HEADER INSTALL ASAP...
alright i started by losening the bolts.. where the down pipe is connected to the cat there are bolts and springs keeping the bolts tight.. when i unscrew it doesnt unscrew do i need two rachets?
Old Oct 12, 2004 | 11:12 AM
sexynuts(.)(.)'s Avatar
Default Re: HELP WITH HEADER INSTALL ASAP... (madlion)
prob just need some wd40 to loosen the bolts
Old Oct 12, 2004 | 11:22 AM
madlion's Avatar
Default Re: HELP WITH HEADER INSTALL ASAP... (sexynuts(.)(.))
no i can turn the bolts they just keep turning
Old Oct 12, 2004 | 12:04 PM
accordhybrid's Avatar
you need a box wrench on one side and a socket on the other
Old Oct 12, 2004 | 11:06 PM
Jay84ever's Avatar
Default Re: (accordhybrid)
KICK IT!
Old Oct 13, 2004 | 03:45 PM
AVcTcEoCrd's Avatar
Default Re: (Jay84ever)
yes you need 2 tools, 1 ratchet or air ratchet and a wrench on the other, it doesnt matter which sides you put em on, jus make sure they are both going in the correct direction
GSRerrr
Mar 4, 2005 08:50 PM
94B18B1Teg
Mar 15, 2004 11:05 AM
lenn
Nov 24, 2003 01:35 PM
Agent STFU
Jul 24, 2003 11:09 PM
SamC
Feb 28, 2002 07:37 AM
