SOHC OBX Turbo Manifold any good?
Old Oct 12, 2004 | 08:30 AM
trooper0641's Avatar
Default SOHC OBX Turbo Manifold any good?
Does anybody run this manifold?
Old Oct 12, 2004 | 08:56 AM
zseeanz's Avatar
Default Re: SOHC OBX Turbo Manifold any good? (trooper0641)
garbage....OBX=
Old Oct 12, 2004 | 09:57 AM
ATS*Mark's Avatar
OG triple OG
Default Re: SOHC OBX Turbo Manifold any good? (zseeanz)
if these things were made of thicker material they would be the **** . but they are thin wall material and crack , dont get it.
Old Oct 12, 2004 | 10:05 AM
turbo_ef9's Avatar
Default Re: SOHC OBX Turbo Manifold any good? (Hella_JDM)
why do people still ask stupid questions about obx mani...? they freaking suck.. crack.. worthless..
Old Oct 12, 2004 | 10:06 AM
CRX T-Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">if these things were made of thicker material they would be the **** . but they are thin wall material and crack , dont get it.</TD></TR></TABLE>
Did you mean better material??
Thicker does not mean it will be better.
Those manifolds are at least better then the SSA......... ones(Dare not mention that name )
Old Oct 12, 2004 | 10:28 AM
Slammd Sol's Avatar
You can run of of these manifolds just fine so long as you: brace the manifold from the block to reduce the amount of weight/vibration being put on it, port the wastegate exit, and have a flex pipe in your exhaust.
Old Oct 12, 2004 | 10:38 AM
ATS*Mark's Avatar
OG triple OG
Default Re: SOHC OBX Turbo Manifold any good? (CRX T-Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX T-Si &raquo;</TD></TR><TR><TD CLASS="quote">Did you mean better material??
Those manifolds are at least better then the SSA......... ones(Dare not mention that name )</TD></TR></TABLE>
actually they are the exact same , spark racing , ss autochrome and obx manis are the exact same . and the material is ok , its just too thin.
Old Oct 12, 2004 | 10:39 AM
RyanEJ8's Avatar
Default Re: (Slammd Sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammd Sol &raquo;</TD></TR><TR><TD CLASS="quote">You can run of of these manifolds just fine so long as you: brace the manifold from the block to reduce the amount of weight/vibration being put on it, port the wastegate exit, and have a flex pipe in your exhaust.</TD></TR></TABLE>
Bracing can actually cause the manifold to be more likely to crack. If it's made of different material/metal it will have a different heat expansion rate.
Old Oct 12, 2004 | 10:42 AM
ATS*Mark's Avatar
OG triple OG
Default Re: (RyanCivic2000)
when you brace a manifold yourself , your eliminating the expansion points the manufacturer built into it.
Old Oct 12, 2004 | 10:45 AM
Rory Breaker's Avatar
Default Re: (Hella_JDM)
The weight of the turbo/wastegate cannot be supported by the thin material. Brace at least the turbo and you should be fine.
This has been gone over a thousand times...
RACEPAK
Aug 21, 2007 02:17 PM
trooper0641
Jun 29, 2006 01:48 PM
_HANS
Apr 3, 2006 02:25 PM
Quade
Feb 20, 2006 02:35 PM
THE GAME IS THICK
May 25, 2005 10:56 PM
