just put d16z6 into eg and wont start
Old Oct 11, 2004 | 10:56 PM
kaoss_11's Avatar
B A N N E D
Default just put d16z6 into eg and wont start
it will crank and act like it wants to start but it wont, could this be because of any fuses? also could it be the fuel pump because i did hear it when i turn the car into the on position. any opinions would be helpful
Old Oct 11, 2004 | 11:26 PM
snowshooz's Avatar
Default Re: just put d16z6 into eg and wont start (kaoss_11)
crank position sensor O.K. ? had similar problem new sensor did the trick
Old Oct 12, 2004 | 12:15 AM
NIKE SB'd's Avatar
I'm gonna be brief... do a search, check the usual suspects, I would say most likely it's something spark related, namely the coil. If you didn't hear the fuel pump then check your main relay, it very well could be the culprit.
Old Oct 12, 2004 | 07:54 AM
dohcdelsol93's Avatar
Default Re: (BLAME_canada)
also double check grounds
Old Oct 12, 2004 | 07:56 AM
authentic plusONErandy's Avatar
Default Re: (dohcdelsol93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcdelsol93 &raquo;</TD></TR><TR><TD CLASS="quote">also double check grounds</TD></TR></TABLE>
yes a bad ground could cause a lot of trouble
Auxient
Jul 17, 2018 03:34 PM
civic_sieg
Apr 6, 2015 08:10 AM
hytechb20
Feb 20, 2012 07:15 PM
classciv
10
Jan 17, 2006 06:37 AM
MADEinJAPAN
Sep 27, 2003 09:36 PM
