b16 in eg what axles should i use
what axles should i use in a eg with a jdm b16 w/ a gsr trans. ive used gsr axles in it for a while now but i put a new one in recently and it clicks already. i am not sure if it matters but could it be a gsr axle for anti lock brakes? does it make a difference?
Re: b16 in eg what axles should i use (geekuskahn6)
You putting down decent power? Dump the clutch a lot? Maybe you should check out some aftermarket axles. http://www.driveshaftshop.com/
Re: b16 in eg what axles should i use (HybridEJ1)
He does not need aftermarket axles unless if his making insane power, like 250whp +
Just get the clutch rebuilt. I know on my swap if my axles go out i cant buy a new one i need to get it rebuilt, because one was stretched to fit my car.
Re: b16 in eg what axles should i use (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">He does not need aftermarket axles unless if his making insane power, like 250whp + </TD></TR></TABLE>
250whp insane to you?? thats nothing ive seen a gsr 25psi nearly 600whp with stock axels in honda tuning magizine
Re: b16 in eg what axles should i use (opkjoblacsh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by opkjoblacsh »</TD></TR><TR><TD CLASS="quote">
250whp insane to you?? thats nothing ive seen a gsr 25psi nearly 600whp with stock axels in honda tuning magizine </TD></TR></TABLE>
I was talking more for AllMotor, i hope to hit 250whp next time i go to the dyno with my turbo GSR
1) this is not the hybrid forum.
2) stock integra should be fine since you didn't say you were running anything other than a stock engine.
pnwjdm
12-23-2012 08:57 PM
