is my ecu fried!!!
Old Oct 11, 2004 | 07:48 PM
T3T495GSR's Avatar
Default is my ecu fried!!!
ok i have a b16 block with a b18 head with edelbrock manifold and aem fuel rail, aem fpr and full drag 3 turbo kit. im also using the stock gsr ecu right now. my question is "how come i blowing ecu fuses when i let off the gas"? for instance i could back up and then get ready to go forward and then my car will just die and you cant start the car anymore. and it turns out that the 15amp ecu fuse keeps blowing... how is this? do i need a new one? can this have anything to do with another fuse under the dash possibly? thanks
Old Oct 11, 2004 | 08:06 PM
T3T495GSR's Avatar
Default Re: is my ecu fried!!! (T3T495GSR)
bump
Old Oct 11, 2004 | 08:16 PM
T3T495GSR's Avatar
heres what i dont get. the car ran fine until i put the turbo kit back on. as soon as i started it it started running crappy and blowing fuses. i didnt touch any wires so how can this be?
Old Oct 11, 2004 | 08:25 PM
Kamin's Avatar
you have a wire shorting to ground on the ECU main power circut. start tracing wires.
Old Oct 11, 2004 | 08:46 PM
tegmech's Avatar
Start first by checking everything that has been added on. Check with the latest things(boost controller, turbo timer etc.) and make sure nothings shorting from thier.
uberEFtuner
Oct 2, 2013 10:26 PM
K i l l a B e e.
11
Sep 1, 2008 01:08 AM
Quick.Silver
May 24, 2006 11:56 AM
onepoint-gsr
Feb 28, 2006 01:55 AM
Tinker219
Oct 2, 2004 09:24 PM
