ls/vtec swap and stock fuel pump
Old Oct 11, 2004 | 02:28 PM
Brick Top's Avatar
Default ls/vtec swap and stock fuel pump
im runnin an ls/vtec in my 89, still using the stock 1.5 fuel pump.
sometimes vtec cuts in and out like its leaning out, or something. everything is hooked up right. is the stock fuel pump not strong enough for the 1.8? its running 39psi with the hose pinched. runnin stock fuel parts. thanks
Old Oct 11, 2004 | 03:43 PM
mrspeaker's Avatar
Default Re: ls/vtec swap and stock fuel pump (efhatch)
Pump is good for 50psi...
Do u have a chip..?? Sometimes chips cause problems like that..
Old Oct 11, 2004 | 04:08 PM
Brick Top's Avatar
Default Re: ls/vtec swap and stock fuel pump (Mrspeaker)
nope, no chip. stock pr3.
does a knock sensor have anything to do with vtec?
cause mine has been soldered back together.
SmYrE
Apr 16, 2009 03:54 PM
iliv2xlr8
Mar 9, 2009 04:39 PM
AMLS4dr200whp
Aug 18, 2005 07:14 AM
JayDM_EK9
Mar 31, 2005 04:00 PM
1 speedstar
Apr 22, 2003 03:09 PM
